GT23
Jul 23, 2021Guide
Firmware 2.7.3.22 not showing devices
Everything was dialed in on the previous firmware until the upgrade. Now I cannot see my ecobee thermostats even though they are connected and working. Anyone else seeing issues?
- Jul 25, 2021I can try a factory default reset. i don’t recall that a requirement in the release notes. I’m assuming reset will not downgrade firmware
Jul 23, 2021Guru - Experienced User
Whare are you not seeing this?
Orbi App? RBR Web page?
Thermostats only devices not being displayed?
Provide a screen capture of what your seeing would be helpful. Please use the Choose File button to include this on your next post.
- GT23Jul 25, 2021GuideNot seeing ecobee devices using app or mac browser. Should be showing under 2.4Ghz section but looking at ALL connections, including guest, every device on there is accounted for. FYI app is latest version 2.10.5.17
