GT23
Jul 23, 2021Guide
Firmware 2.7.3.22 not showing devices
Everything was dialed in on the previous firmware until the upgrade. Now I cannot see my ecobee thermostats even though they are connected and working. Anyone else seeing issues?
- Jul 25, 2021I can try a factory default reset. i don’t recall that a requirement in the release notes. I’m assuming reset will not downgrade firmware
GT23
Jul 25, 2021Guide
Not seeing ecobee devices using app or mac browser. Should be showing under 2.4Ghz section but looking at ALL connections, including guest, every device on there is accounted for. FYI app is latest version 2.10.5.17
Jul 25, 2021Guru - Experienced User
- GT23Jul 25, 2021GuideI can try a factory default reset. i don’t recall that a requirement in the release notes. I’m assuming reset will not downgrade firmware
- FURRYe38Jul 25, 2021Guru - Experienced User
It doesn't. FRs are a troubleshooting step when problems appear.
- GT23Jul 30, 2021GuideThe factory reset did it. I now see all devices. Thank you!
- FURRYe38Jul 30, 2021Guru - Experienced User
Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemEnjoy. :smileywink:
