JonBrowning
Jan 21, 2025Aspirant
Firmware (2.7.5.6 ???) : RBR50 & RBS50
I have recently been experiencing very regular drops of my RBR50 & satellites. I have updated the firmware on the RBR50 from the config page and it applied V2.7.5.6 and all appears to be OK. I th...
Jan 21, 2025Guru - Experienced User
NG has not posted the updated files yet.
So using the RBRs web page doesn't show the RBS having any FW updates?
JonBrowning
So, it said the RBR could/should be updated (from the actual admin/config page on the RBR itself). It downloaded and installed automatically.
The RBS wants a location for the firmware as it won't update automatically. Hence me now looking for that to keep them aligned.
- JonBrowningJan 21, 2025AspirantI have just figured it out. The phone app does not offer the update for the RBS when logging in as admin. ... The full web page flavour does show it.
- FURRYe38Jan 21, 2025Guru - Experienced User
Are the RBS still connected after the RBR updated? If so, then you might run it as is until NG gets the files posted. Or downgrade the RBR back to prior version.
