JonBrowning
Jan 21, 2025Aspirant
Firmware (2.7.5.6 ???) : RBR50 & RBS50
I have recently been experiencing very regular drops of my RBR50 & satellites. I have updated the firmware on the RBR50 from the config page and it applied V2.7.5.6 and all appears to be OK. I th...
Jan 21, 2025Guru - Experienced User
NG has not posted the updated files yet.
So using the RBRs web page doesn't show the RBS having any FW updates?
JonBrowning
That's it needed to access via true web page not phone app to get that extra functionality. Thanks.
- FURRYe38Jan 21, 2025Guru - Experienced User
Ah, there you go. Ya, I don't recommend using the Orbi app or a mobile device to update the system. Wired PC and web browser is best.
After the system is updated, I'd power everything OFF for 1 minute then back ON with the RBR first, then RBS lastly. Should be good after that.
- JonBrowningJan 21, 2025AspirantReally appreciated thank you.
