JonBrowning
Jan 21, 2025Aspirant
Firmware (2.7.5.6 ???) : RBR50 & RBS50
I have recently been experiencing very regular drops of my RBR50 & satellites. I have updated the firmware on the RBR50 from the config page and it applied V2.7.5.6 and all appears to be OK. I th...
JonBrowning
That's it needed to access via true web page not phone app to get that extra functionality. Thanks.
Jan 21, 2025Guru - Experienced User
Ah, there you go. Ya, I don't recommend using the Orbi app or a mobile device to update the system. Wired PC and web browser is best.
After the system is updated, I'd power everything OFF for 1 minute then back ON with the RBR first, then RBS lastly. Should be good after that.
- JonBrowningJan 21, 2025AspirantReally appreciated thank you.
- FURRYe38Jan 21, 2025Guru - Experienced User
