MareLuce
Jun 14, 2019Aspirant
Firmware Check Error
I am seeing the Firmware Check Error shown below when I try to upgrade to 2.3.1.60 Is there anything else I could try before installing manually? The routers are not easy for me to physically acce...
maxhowells7
Sep 10, 2019Aspirant
The firmware error you are facing just because of the problem Wii Error Code 51330 and for that you need to understand about the security of the router. Just do one thing updated the router's software then I believe you will not face this problem again.
- MareLuceSep 10, 2019Aspirant
The solution to the problem:
Update the firmware by connecting my laptop to the router address via a web browser to 192.168.x.x. (I don’t recall the exact address)
NOT update via the iOS app
the iOS app can’t update correctly. The browser works fine.
that is the solution.
- FURRYe38Sep 10, 2019Guru - Experienced User
Yes, thanks for letting is know it works for you. We've seen issues with the Orbi App. Hopefully NG can get this fixed in the app.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
MareLuce wrote:The solution to the problem:
