rxchristina
Sep 15, 2019Aspirant
Firmware check error
Received an email from Netgear to update firmware on Orbi rbr 50. Tried it and got the message “firmware check error”. The latest version I have is 2.3.1.60. Anyone having this problem? Any solution? ...
- Sep 15, 2019
Pg 89 of the user manual gives information on how to do FW updates thru the RBRs web page:
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
Just try to remember that the RBS needs to be updated first, then update the RBR lastly.
Enjoy. :smileywink:
Sep 15, 2019Guru - Experienced User
Is this via the Orbi app or RBRs web page? Plese use a PC connected to the RBR and web browser to update the FW on the RBS first, then the RBR lastly.
If your system is running fine, you may want to not update as well.
- rxchristinaSep 15, 2019AspirantMy Current fw version is 2.3.1.60, hardware version is RBR50, hardware type is ORBI.
This was through the ORBI app.
Yes the system is currently running fine but since the email I received stated the latest fw is v2.3.5.30 which will enhance the product security, I thought I should update.
Any thoughts? Or just leave as is since everything is running ok?
Thanks- FURRYe38Sep 15, 2019Guru - Experienced User
Yes users are seeing odd issues with the Orbi app. We recommend using the RBR web page for doing any FW updates.
However if your system is running fine, you'll be ok to leave it.
- rxchristinaSep 15, 2019AspirantThank you!
