rxchristina
Sep 15, 2019Aspirant
Firmware check error
Received an email from Netgear to update firmware on Orbi rbr 50. Tried it and got the message “firmware check error”. The latest version I have is 2.3.1.60. Anyone having this problem? Any solution? ...
- Sep 15, 2019
Pg 89 of the user manual gives information on how to do FW updates thru the RBRs web page:
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
Just try to remember that the RBS needs to be updated first, then update the RBR lastly.
Enjoy. :smileywink:
rxchristina
Thank you!
Sep 15, 2019Guru - Experienced User
Enjoy. :smileywink:
- rxchristinaSep 15, 2019AspirantGot it!
Thank you very much!- FURRYe38Sep 15, 2019Guru - Experienced User
:smileywink:
