Daniela_0924
Jul 11, 2021Aspirant
Firmware Check Error
I have had the Orbi RBR20 router with one satellite for over a year now and it has made all the difference with WiFi coverage in my home. Every now and then, I do check for firmware updates via the a...
Jul 11, 2021Guru - Experienced User
- Daniela_0924Jul 11, 2021Aspirant
It is a modem we got from Spectrum. The model number is ET2251.
- FURRYe38Jul 11, 2021Guru - Experienced User
Ok, just checking to see if the modem had a built in router or not.
Sometimes the FW update services get stuck and users may see this FW update check error. If you really wanna update then follow the suggestions. You don't have to update as well if your system is working well for you.
