Daniela_0924
Jul 11, 2021Aspirant
Firmware Check Error
I have had the Orbi RBR20 router with one satellite for over a year now and it has made all the difference with WiFi coverage in my home. Every now and then, I do check for firmware updates via the a...
Jul 11, 2021Guru - Experienced User
The most recent firmware for the rbr20 is 2.6.2.104
You're not up to date. I'd try manually updating.
Make sure to update the satellites first. I didn't include a link for the satellites as there's different versions.
go to netgear.com/support/ type in the satellite version and it'll have the firmware you can download.
Daniela_0924
If V2.6.2.104 is the most recent firmware version, then I am running it. I checked the website and there is no newer version for this particular model.
