CrimpOn
Aug 08, 2019Guru - Experienced User
FirmWare Corrupted
I just bought a new RBK53 for my son and had Amazon deliver it to his house (clear across the United States). I came on a visit to replace his old Nighthawk with the Orbi, and one of the two satelli...
- Aug 08, 2019
You might try to see if you can get FW loaded via the TFTP method on the RBS:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
IF this fails, send back to Amazon. :smileyfrustrated:
CrimpOn
Bless You, it worked! Naturally, I had brought my lightest laptop running Linux. Back to the command line to load and run tftp client. I gave this less than a 1% chance, and the satellite updated to 2.3.5.30 and connected automatically!
- FURRYe38Aug 08, 2019Guru - Experienced User
Awesome. Glad it worked.
Enjoy. :smileywink:
