helpme1234
Sep 02, 2023Aspirant
Firmware disk image update files won't mount, Mac
Every disk image I download for firmware update fails to open on both a Mac and Windows machine. Anyone have a solution? And the automatic updates don't work. Thanks.
1 Reply
These are not disk images., They are firmware files with the extension .img.
You do not "open" them.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
Check the section in the manual on updating the firmware.
