Helmy
Apr 18, 2020Initiate
Firmware for Satellite
I just installed a new satellite. My router and original satellite firmware is v2.5.1.8 but the new one is v2.3.5.30 I checked using net gear website and it says no firmware updates needed. Do I n...
Retired_Member
Apr 18, 2020
Do I need to update my new satellite? How to update the individual satellite?
Usually the firmware numbers are the same across corresponding router and sats
BTW. Lots of problems with 2.5.1.8
you may want to revert those devices to 2.3.5.30.
- HelmyApr 25, 2020InitiateThank you
