Helmy
Apr 18, 2020Initiate
Firmware for Satellite
I just installed a new satellite. My router and original satellite firmware is v2.5.1.8 but the new one is v2.3.5.30 I checked using net gear website and it says no firmware updates needed. Do I n...
Apr 18, 2020Guru - Experienced User
All you need to do is update the FW manually on the RBS.
You can download FW udpates from NGs support site:
https://www.netgear.com/support/product/RBK50.aspx#download
- Retired_MemberApr 18, 2020
manual updates is neither recommended or needed
