altern8
Sep 01, 2018Aspirant
Firmware mismatch
This morning, i received an notification that an new firmware was available for my RBR20/RBS20 unit so I proceeded with the update. After the dust settled, I noticed the update only took place for t...
Sep 01, 2018Guru - Experienced User
Yes. Check to see if there is a RBR match as well. There should be however if there isn't thats ok. the RBS can have the newer version. Just update the satellites first when doing FW updates.
- altern8Sep 01, 2018Aspirant
Thanks for the quick reply!
Sorry, I should have elaborated on my post. The update was performed thru the Orbi iOS app (I typically do it thru the web portal but I was lazy this morning). After the update completed, I checked the firmware version and noticed only the RBR unit was updated v2.2. No problem I thought, let me go to Netgear's website to download and perform a manual update on the satellite but the latest version of firmware for RBS20 is listed as v2.1.
- FURRYe38Sep 01, 2018Guru - Experienced User
You might leave the RBS alone for now. If the system is working after the update. You can wait for a future update for the RBS.
great, ty.
i was hoping to finally get ethernet backhaul working but after plugging in my ethernet, the satellite went offline and stayed there until i removed the cable. guess i will just have to wait.
