LaSabana
May 25, 2021Aspirant
Firmware not updating on NetGear web site or via smart phone
Unable to update firmware from the website or from my smart phone. This system is equipped with Satellite RBW30. On the Smart phone i am seeing CHECK FIRMWARE Error and on the ORBI site i get an indi...
- Feb 18, 2022
Manual update requires that the zip file be "unpacked" to extract the actual firmware image, which in the case of the RBW30 has a file extension of chk. It is not clear from the post if that step was done.
CrimpOn
May 25, 2021Guru - Experienced User
can you try connecting directly to the web site of the RBW30 satellite. Its IP address will appear in the web interface Attached Devices display.
- LaSabanaMay 25, 2021Aspirant
Thanks Crimp On, I have the Satellite IP address; is there some action should take with IP address?
- CrimpOnMay 25, 2021Guru - Experienced User
the satellite web page should have a menu item for "Firmware Update", where you can upload the *.chk file that came from Netgear support site.
- LaSabanaMay 25, 2021AspirantThanks CrimpOn,
Are you suggesting that I log into the satellite ip address site and see if there is a firmware update?
