bearyoung
Oct 25, 2019Aspirant
Firmware of europe
I bought a rbk23 in US, will move to Germany soon, can I use it's newst firmware of Europe? Will I brick the orbi?
Oct 25, 2019Guru - Experienced User
FW is not region specific. You can select from the drop down box under the log out button on the RBRs web page to select a country listed i n the drop down.
CrimpOn
Oct 27, 2019Guru - Experienced User
FURRYe38 wrote:FW is not region specific. You can select from the drop down box under the log out button on the RBRs web page to select a country listed i n the drop down.
I may be mistaken, but I think the drop down menu under the Logout button is to select the language rather than the WiFi Region.
- FURRYe38Oct 27, 2019Guru - Experienced User
Yes, this was my intended understanding and responce. I should have included that as well.
Thanks.
