gm2t2
Dec 20, 2017Aspirant
Firmware Problems w/ Satellites
I updated the firmware on my router before I installed my satelite firmware update. It will not upadte the satelite through software or by doing it outside software. When I go to software update I g...
- Dec 21, 2017
That .img file looks correct.
Did you unzip the file that you downloaded or are you trying to load it from within the zipped file?
Streak2
Dec 20, 2017Master
Have you tried using manual update?
Select the satellite you want to update and then upload the update that you can get from here
