franktribe
Aug 27, 2019Apprentice
Firmware Question...
To preface, my Orbi system is rock solid. I have an RBR50 and 2 satellites. I am using Ethernet backhaul and do not have any issues with it. My wifi calling works when roaming. My Ring devices work g...
- Aug 27, 2019
franktribe wrote:If I decide to skip this firmware and another one is released, do I need to upgrade to V2.3.5.30 before going to the next version? Or can I skip V2.3.5.30 and upgrade to the next version when it comes out?
Only one firmware update has required an "intermediate step". That was when the size of Orbi firmware exceeded the maximum that the installer was programmed to handle. Netgear produced a special firmware release for the sole purpose of changing the maximum firmware size. My guess is you can be pretty confident that you can skip this release and update to a new one when you want to.
On the "down side", suppose that someday you do need to install an intermediate firmware before making the "ultimate leap." You do not have to endure the intermediate firmware for an extended time. Simply update, then update again.
Good Luck
Retired_Member
Aug 27, 2019
franktribe wrote:To preface, my Orbi system is rock solid. I have an RBR50 and 2 satellites. I am using Ethernet backhaul and do not have any issues with it. My wifi calling works when roaming. My Ring devices work great. It has been running very well on Firmware V2.3.1.60. That firmware feels very reliable on my system. I am investigating V2.3.5.30. But, I don't see any benefits, the bug fixes don't seem to apply to me. So, my question is more about the firmware release cycle and process. If I decide to skip this firmware and another one is released, do I need to upgrade to V2.3.5.30 before going to the next version? Or can I skip V2.3.5.30 and upgrade to the next version when it comes out?
Glad to hear your Orbi is working well. My sugesstion, leave it alone. NG changed their FW auto update policy to where now they only push (auto) updates that contain major revisions/updates. Often people feel the urge to update and end up with problems.
With regard to your update progression questions, your best bet is to get on over to the NG support / download section. (https://www.netgear.com/support/product/orbi.aspx#download)
They talk about who's on first and who stole second. Good luck!
