franktribe
Aug 27, 2019Apprentice
Firmware Question...
To preface, my Orbi system is rock solid. I have an RBR50 and 2 satellites. I am using Ethernet backhaul and do not have any issues with it. My wifi calling works when roaming. My Ring devices work g...
- Aug 27, 2019
franktribe wrote:If I decide to skip this firmware and another one is released, do I need to upgrade to V2.3.5.30 before going to the next version? Or can I skip V2.3.5.30 and upgrade to the next version when it comes out?
Only one firmware update has required an "intermediate step". That was when the size of Orbi firmware exceeded the maximum that the installer was programmed to handle. Netgear produced a special firmware release for the sole purpose of changing the maximum firmware size. My guess is you can be pretty confident that you can skip this release and update to a new one when you want to.
On the "down side", suppose that someday you do need to install an intermediate firmware before making the "ultimate leap." You do not have to endure the intermediate firmware for an extended time. Simply update, then update again.
Good Luck
Aug 27, 2019Guru - Experienced User
Also be sure to save off a current backup configuration to file for safe keeping for each version of FW you get loaded. Comes in handy when you want to save time after FW updates.
Good Luck.
franktribe wrote:To preface, my Orbi system is rock solid. I have an RBR50 and 2 satellites. I am using Ethernet backhaul and do not have any issues with it. My wifi calling works when roaming. My Ring devices work great. It has been running very well on Firmware V2.3.1.60. That firmware feels very reliable on my system. I am investigating V2.3.5.30. But, I don't see any benefits, the bug fixes don't seem to apply to me. So, my question is more about the firmware release cycle and process. If I decide to skip this firmware and another one is released, do I need to upgrade to V2.3.5.30 before going to the next version? Or can I skip V2.3.5.30 and upgrade to the next version when it comes out?
Anonymous
Aug 27, 2019
FURRYe38 wrote:Also be sure to save off a current backup configuration to file for safe keeping for each version of FW you get loaded. Comes in handy when you want to save time after FW updates.
Perhaps.....However, not necessary IF you take the hands off approach.
