kawaiikoibito28
Jun 04, 2020Aspirant
Firmware RBR40 2.5.1.16 keep disconnecting and auto update again after downgrade
I had a RBR40 and RBS40 which was working fine ever since I bought it last year. But since yesterday the firmware got auto upgrade to 2.5.1.16 and it had been disconnecting every few mins. I tried to...
TimmyTechTV
Jun 06, 2020Tutor
FURRYe38 wrote:Keep us posted...
I am having the same issues after being auto upgraded to 2.5.1.16 on my RBR50. Last 2 days have been horrible and its affecting my ability to work from home.
Anyone figure anything out yet?
Jun 06, 2020Guru - Experienced User
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
- TimmyTechTVJun 06, 2020Tutor
I was asking Kawaii if they had tried yet.
That said, as a software engineer, nothing you have in that list should need to be done after a firmware upgrade. If you have to factory reset to fix an issue, Netgear needs to fix their QA process.
My system has been rock solid for 2 years before this FW upgrade. Someone at Netgear dropped the ball, again...
- FURRYe38Jun 06, 2020Guru - Experienced User
You have your options. Factory resets are valid and necessary in troubleshooting problems with any networking device. There maybe bad configurations or issues seen that cause problems. Not nessarily FW or coding problem. Factory resets have been apart of networking troubleshooting for years. Yes at most of the time, they shouldn't be needed however when needed, they do come in handy and have and do solve problems. Been many posts where they do.
I'm on v16 with my RBK50 and haven't seen any issues since loading it. Working very well for me.
If the newer FW isn't working for you, then you may want to revert back if you don't want to do a reset.
Good Luck.- TimmyTechTVJun 06, 2020Tutor
I do appriciate your help, this is just pretty annoying.
I've run 5000+ server labs with crazy network setups, and while I have had to reset managed switches and routers before (even F5 NLBs), I guess I'm just used to that being called out by the company ahead of time in the upgrade instructions. Difference between enterprise and consumer I guess.
Of course, they don't auto push those updates either. ;)
