kawaiikoibito28
Jun 03, 2020Aspirant
Firmware RBR40 2.5.1.16 keep disconnecting and auto update again after downgrade
I had a RBR40 and RBS40 which was working fine ever since I bought it last year. But since yesterday the firmware got auto upgrade to 2.5.1.16 and it had been disconnecting every few mins. I tried to...
madhur77
Jul 11, 2020Aspirant
Hi,
I have a RBK50 (RBR50 & RBS50) system and have also been going nuts the last week and a half when my satellite started acting strange with firmware update to 2.5.1.16. The wireless backhaul status kept changing from 5G to 2.4G. Stable for some time and then again disconnects and reconnects to the router and effectively the same cycle kept happening. I did all resets of both router and the satellite, but nothing worked. Then i happened to check for any updates and i found that there was one 2.5.1.32. The following were the bug fixes for the same.
Bug Fixes:
- Fixes the incorrect power setting on the WiFi Transmit Power Control
- Fixes potential issues with the Armor activation
The first bug caught my interest as i felt that it could be the reason for the switching. I updated to this firmware and did a complete reset and set it up from scratch. It been up 12hrs and everything is working stable without any switching. I think we are back to the good old days of correct good bandwidth with these mesh system.
Maybe the RBR40 might also be having the same issue and might be getting an update soon.
Hope this helps. Thanks.
-Maddy
TimmyTechTV
Jul 12, 2020Tutor
madhur77 wrote:Hi,
Bug Fixes:
-Maddy
Too bad I had to replace mine since I was about to get fired for being offline all the time...
Thanks for the update!
