kawaiikoibito28
Jun 03, 2020Aspirant
Firmware RBR40 2.5.1.16 keep disconnecting and auto update again after downgrade
I had a RBR40 and RBS40 which was working fine ever since I bought it last year. But since yesterday the firmware got auto upgrade to 2.5.1.16 and it had been disconnecting every few mins. I tried to...
AlHitmi
Jul 11, 2020Aspirant
Hello,
Since my last comments, I did nothing but changing the port that was connecting my RBR50 to the main router and somehow that did the trick, my connection been up for almost 24 hours now, with no issue. After I checked I saw that there is indeed a new FW update (2.5.1.32). However, when I checked for an update through my router setting page it is showing no new update available. Given that I have a stable connection now, do you guys think I should manually update to the new FW or do nothing since I have no issue now.
Hitmi
Jul 13, 2020Guru - Experienced User
IF you have no issues or problems, it best to keep whats loaded for now. You can manually download v32 FW Files and apply them if you want to. Or just download them and keep them handly for later on. v32 is a minor FW update.
AlHitmi wrote:Hello,
Hitmi
