sabrinamane
Mar 09, 2021Guide
Firmware update - disconnection of Orbi router
Hello, I had lot of issues when i have installed Orbi on my Etisalat Modem. I had to disconnect Armor that was creating lot of disconnection (many times per day). Now it is working properly, how...
vajim
Mar 09, 2021Master
sabrinamane wrote:Hello,
Now it is working properly, however, everytime thereis a Fireware update, this will again disconnect my Orbi router. It can take 20 min when I turn it off and on again to make it work.
This is always happening middle of day, which is not easy when we are working from home, and in a middle of an important call.
Who can help me to fix this issue as it is very annoying?
Thanks,
Sabrina
Stop performing firmware updates
sabrinamane
Mar 09, 2021Guide
how to do that?
- vajimMar 09, 2021Master
sabrinamane wrote:how to do that?
do what...perform firmware updates?
Most updates are user initiated. Meaning you have to go looking and then click something.
My advice is IF your Orbi is working good, leave it alone and enjoy it. That's all
- sabrinamaneMar 09, 2021Guide
Actually the firmware is installed automatically when there is a new version. if there is an option to stop this automatic refresh, that could be great, so i can update it manually instead at the end of a day when there is a new one. i am not sure how to stop the automatic installation and switch it to manual one instead.
sabrinamane wrote:Actually the firmware is installed automatically when there is a new version. if there is an option to stop this automatic refresh, that could be great, so i can update it manually instead at the end of a day when there is a new one. i am not sure how to stop the automatic installation and switch it to manual one instead.
define "automatically"
I've not seen fully automatic in several years.
