Besselink
Jan 03, 2021Follower
Firmware Update 2021
Happy New Year. I received an email regarding an "Important Security Firmware Update from NETGEAR." Note: my ORBI system was purchased through Verizon a couple of years back. When I go into the...
Jan 03, 2021Guru - Experienced User
If yours was purchased thru Verizon, contact Verizon as they have contracted with NG to put there own FW on Orbi systems thus you cant use NG stock FW on Verizon branded Orbi.
Good Luck.
vajim
Jan 03, 2021Master
FURRYe38 wrote:If yours was purchased thru Verizon, contact Verizon as they have contracted with NG to put there own FW on Orbi systems thus you cant use NG stock FW on Verizon branded Orbi.
Good Luck.
Wow if this IS true you don't have to worry about all of the confusion here in this forum
- CrimpOnJan 03, 2021Guru - Experienced User
Yes, this specific question has come up several times and the "bottom line" has always been that (a) the Verizon branded Orbi product has something hard coded in it that rejects any attempts to load Netgear firmware on it, and (b) Verizon has never issued a firmware update. Never. I would have to look through the posts, but my memory is that even TFTP fails on the Verizon units. Isn't this a hoot. Netgear sends email to people who cannot update firmware telling them they should.
- vajimJan 03, 2021Master
CrimpOn wrote:Yes, this specific question has come up several times and the "bottom line" has always been that (a) the Verizon branded Orbi product has something hard coded in it that rejects any attempts to load Netgear firmware on it, and (b) Verizon has never issued a firmware update. Never. I would have to look through the posts, but my memory is that even TFTP fails on the Verizon units. Isn't this a hoot. Netgear sends email to people who cannot update firmware telling them they should.
Yes to add to the already confusion
