LifeAsCason
Apr 10, 2020Aspirant
Firmware Update CBR40 2.3.5.30?
Each time I enter my Orbi app on my iPhone, I'm prompted with a message that shows that there is an update available. The app shows that my current firmware is "2.3.5.12" and the new update is "2.3.5...
LifeAsCason
Apr 13, 2020Aspirant
Blanca_O
Here is a screenshot of all of the firmware on my system.
I can see the firmware you mentioned “ v2.3.5.30” in the NETGEAR downloads page for the RBS50 but is it not an older version that the “V2.5.1.8”? It says no new firmware for any of my devices so I’m confused.
Apr 17, 2020Guru - Experienced User
Use a web browser and manually download the FW files from NG support site for the RBS and CBR. Apply the FW files manually using the web browser connected to the RBS first, then the CBR lastly. I would factory reset both and then setup from scratch.
LifeAsCason wrote:
Blanca_O
- Frankster1101Apr 26, 2020InitiateThe responses I see to this problem of updates go beyond the capabilities of most folks. I have the same issue. What I have read is in the update package is only adding new armor feature to your platform to sell you a subscription. If there is a update check feature in your hardware and it doesn’t work as they designed. Then they should offer a free case to call in and get support. Not happy with all the $$$ I have spent CBR40 & 3 RBS20s. I have satellites that randomly disconnect. I have read all things to try. Move them around, made power adjustments, channel changes. At best I can keep everything connected 60-70% of the time. Pain in the ass. Sorry good concept but if you have to become a wireless router guru to keep running. It’s not worth more $$$$
- FURRYe38Apr 27, 2020Guru - Experienced User
What FW version do you have loaded on the CBR40 and RBS?
Current version for the CBR is 2.3.5.12, 2.5.1.16 for RBS20s.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Has a factory reset on the CBR and RBS been performed since last update?
IF you want or need NG support, you can open up a support ticket here:
https://www.netgear.com/support/#
