LifeAsCason
Apr 10, 2020Aspirant
Firmware Update CBR40 2.3.5.30?
Each time I enter my Orbi app on my iPhone, I'm prompted with a message that shows that there is an update available. The app shows that my current firmware is "2.3.5.12" and the new update is "2.3.5...
Blanca_O
Apr 13, 2020NETGEAR Employee Retired
Hi LifeAsCason
Welcome to NETGEAR Community!
The latest CBR40 firmware is v2.3.5.12.
The latest RBS50 firmware is v2.3.5.30.
You mentioned that both of the satellites are on the most current version, may I please know the firmware version just to check?
Blanca
Community Team
DocJim
Jun 02, 2020Aspirant
I believe that for CBR 40 you are correct that the current firmware is V2.3.5.12
I have RBS20 satellites (I don't know about RBS50) and their current firmware is V2.3.5.30
I think that the issue we are having is with the App telling us that the firmware needs updating, and is seeing the CBR40 firmware (which is current) and looking at the update for the RBS20 and since the CBR isn't V2.3.5.30 saying it is out of date . . . which it is not.
Make sense. It's an APP problem.
- FURRYe38Jun 02, 2020Guru - Experienced User
One can manually update the RBS to v16 and then check the app again. Ya, seems that the app maybe incorrect.
