fixmacs
Aug 16, 2019Guide
Firmware update connection now poor
I updated the firmware on the Orbi router and satellitte today. Now the sateliite fails to connect "good." The connection status is now "poor." I restarted the satellite and re-synced the system. Sti...
Aug 17, 2019Guru - Experienced User
Any progress on this?
fixmacs wrote:I updated the firmware on the Orbi router and satellitte today. Now the sateliite fails to connect "good." The connection status is now "poor." I restarted the satellite and re-synced the system. Still "Poor."
- fixmacsAug 21, 2019Guide
No luck. None.
- FURRYe38Aug 21, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.Any Wifi Neighbors near by? If so, how many?
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
