fixmacs
Aug 16, 2019Guide
Firmware update connection now poor
I updated the firmware on the Orbi router and satellitte today. Now the sateliite fails to connect "good." The connection status is now "poor." I restarted the satellite and re-synced the system. Sti...
fixmacs
Aug 21, 2019Guide
No luck. None.
Aug 21, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
