MCatherman
May 14, 2019Aspirant
Firmware update disabled streaming
The latest firmware update, V2.3.1.60, has disabled my streaming capabilities. Any known fixes or how I can revert to the previous firmware version?
- May 14, 2019
Try a factory reset on the system and setup from scratch. Walk thru the setup wizard and do not load a prior saved backup configuration from file. Do a new clean setup.
SW_
May 14, 2019Prodigy
MCatherman, you can revert to a previous version by re-installing your previous version over the current version. By the way, what streaming issue did you run into? Perhaps, someone might be able to help if they understand the issues better.
- MCathermanMay 14, 2019Aspirant
Thanks for the info. I am getting a message indicating I'm not connected to the internet. It's happening my mobile devices for Prime Video and DirecTV.
- FURRYe38May 14, 2019Guru - Experienced User
Reboot the devices and re-connect them to the Orbi...
