Stallion69
Jul 16, 2019Tutor
Firmware Update error
Everytime i try to check for updates on formware, it gives me a "Firmware Check Error". I am currently on version 2.3.1.44. Can anybody help please...
CrimpOn
Jul 16, 2019Guru - Experienced User
Stallion69 wrote:Everytime i try to check for updates on formware, it gives me a "Firmware Check Error". I am currently on version 2.3.1.44. Can anybody help please...
Could you please describe how you are checking for firmware updates? Is it using the web interface and the "Firmware Update" page under Administrarion on the Advanced Tab, or are you using the Orbi app?
Thanks
Stallion69
Jul 16, 2019Tutor
I am using my ORBI App....
