Dway
Aug 02, 2022Aspirant
Firmware update failed on RBW30
RBW30 satellite with firmware v2.6.2.6 (correct as far as I know), when checking for updates shows update failed, whereas with the router RBR40, the response is no new firmware available. This satell...
Aug 02, 2022Guru - Experienced User
If you're on the latest firmware, I wouldn't worry about it.
But if you do want to update, you can always update manually.
Or if you're concerned the firmware is corrupt and thats whats causing the issue.
