Dway
Aug 02, 2022Aspirant
Firmware update failed on RBW30
RBW30 satellite with firmware v2.6.2.6 (correct as far as I know), when checking for updates shows update failed, whereas with the router RBR40, the response is no new firmware available. This satell...
manonamission
Dec 12, 2022Aspirant
I also have this same problem.
I have tried to manually update the firmware but when I go to upload the update file, the website says it's looking for a .img file. The only file included in the update is a .chk file.
Something is amiss here.
See the attached screen shot.
Dec 12, 2022Guru - Experienced User
manonamission You're putting a rbw30 firmware file in the upload location for the router. Not for the satellite. So you're using the wrong file.
- manonamissionDec 12, 2022Aspirant
plemans Thanks for that. I retried the manual update using the correct device this time and it worked properly.
