bg35
Aug 17, 2019Follower
Firmware Update for rbr50 is broken
The firware update system is totally broken. This is so sad. I tried to hit updtae fro the app on mobile device, and it eventually says that update failed. I then tried to hardwire into the orbi a...
Aug 17, 2019Guru - Experienced User
Try using a wireld PC and a web browser to update the RBS first then RBR. The FW update system in the web page IS working.
Weve seen issues with the Orbi app.
Let us know about your ISP modem as well.
bg35 wrote:The firware update system is totally broken. This is so sad. I tried to hit updtae fro the app on mobile device, and it eventually says that update failed. I then tried to hardwire into the orbi and update, and nothing happens-it times out after many hours. I then downloaded the firmware and tried to do a manual firmware update, and the system tells me that the firmware is incorrect even though I am downloading the correct firmware (rbr50 going from version 2.3.1.48 to 2.3.5.30. Come on NetGear, please fix the update system. Otherwise, what is the point
