buyeeronexttime
Dec 25, 2020Aspirant
Firmware update installed not current on website
My Orbi app installed firmware update v 2.7.1.102 @ 0235 Christmas morning and Armor Security started sending audible alerts waking me up! Netgear website DOES NOT show 2.7.1.102 as CURRENT version! C...
- Dec 28, 2020
Well like some others, not all Mfrs have free support. Most free support is for limited time after the unit is purchased and reg'd.
You can get free support here in the forums though. :smileyvery-happy:
Dec 28, 2020Guru - Experienced User
Are you located in the USA region?
What FW version is actually installed on the RBS and RBR? Use a web browser and PC to check this.
What FW version did you have loaded prior?
- buyeeronexttimeDec 28, 2020AspirantYes in USA. Current version is 2.7.1.102. Previous version was 2.7.1.60.
- FURRYe38Dec 28, 2020Guru - Experienced User
You should be fine then. Just makes NG time to post FW files to the support site. Always happens like this.
Enjoy.- buyeeronexttimeDec 28, 2020AspirantThank you, I will take your word for it. I’m very unfamiliar with how all this is supposed to work. Greatly appreciated! Take care!
