NAMetz
Feb 14, 2021Tutor
Firmware Update Issues RBR50
This Orbi system is so frustrating. Works for a while then just goes out for no reason. Woke up to no internet. Looked at support and notice the .104 update. Followed the instructions by the book fo...
NAMetz
Feb 14, 2021Tutor
Thanks for the reply. I do everything through the web interface and have done updates using the manual method as that seems to be the most reliable, but there always seems to be issues with something.
I would rather not have to go through all this factory reset stuff, I’ve wasted half my day already. At least the internet is working.
Do you have to reset the router and satellite or just router? Is there a good link with step by step instructions? Thanks.
Feb 14, 2021Guru - Experienced User
Press the reset button for 15 seconds on the RBS and RBR then release. Walk thru the setup wizard with a wired PC and web borwser.
- vajimFeb 14, 2021Master
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
then leave it alone once it stablizes
