sonocaro
Jan 06, 2021Tutor
Firmware update naar 2.6.1.40 voor RBK50 (geen V, v2)
Beste communityleden, Ik ervaar stabiliteitsproblemen op mijn RBK50 (geen V, V2) Mesh systeem. De Wifi valt om de haverklap weg. Op dit moment heb ik Firmware V2.5.2.4, ik heb op de community gel...
Jan 06, 2021Guru - Experienced User
Engels graag
- sonocaroJan 06, 2021Tutor
Thank you very much for your quik response!
When i brows to the suggested hyperlink (https://kb.netgear.com/000062484/RBR50-RBS50-Firmware-Version-2-6-1-40), i get the page with this hyperlinks, as you can see in de following hyperlinks,thee zip files has V2. When i choose for the V2 download page, i get the same files as here below.
RBR50 - https://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V2.6.1.40.zip
RBS50 - https://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V2.6.1.40.zip
- FURRYe38Jan 06, 2021Guru - Experienced User
Can you get these files?
Seems like you have non V2 FW loaded on your system...
I have downloaded these two files. When i try to manualy upload the .img file of the Satellite to the Satellite (the first step for the update of the mesh system), i get aan Failuer popup. See screenshot please.
You wrote the following " Seems like you have non V2 FW loaded on your system..." how can i load V2 FW if my system is not V2?
Thansk for your response!
