Mkerr33
Aug 19, 2019Tutor
Firmware Update not working
I havent Been able to update my devices for the past 4 or 5 months even though there are updates available. Every time it searches for the update, it says the search field and it can’t download the up...
Aug 19, 2019Guru - Experienced User
Are you using the Orbi app or the routers web page?
Using the web page on the router is preferred.
