Mkerr33
Aug 19, 2019Tutor
Firmware Update not working
I havent Been able to update my devices for the past 4 or 5 months even though there are updates available. Every time it searches for the update, it says the search field and it can’t download the up...
Mkerr33
Aug 19, 2019Tutor
I’ve gotten two emails saying there are updates available and when i do The update through the app it says it can’t complete it. And the Orbi web interface says i am not connected to my orbi wifi, even though i am And I’ve tried it on 3 different browsers.
Aug 19, 2019Guru - Experienced User
What firmware is currently loaded? CrimpOn's method works but if you're on a really old firmware, there's a firmware step in between that you'd need to take.
- Mkerr33Aug 20, 2019Tutor
i'll have to check when i get home but i believe i have been unable to download the last 3 updates. i think it is 2.3.1
i wonder if i just factory reset the system and set them back up again if that would be the easiest thing to do?
- FURRYe38Aug 20, 2019Guru - Experienced User
Can you give us the full FW verison #? The last number value is most important.
You can manually download FW files for your RBR20 here:https://www.netgear.com/support/product/RBR20.aspx#download
With a wired PC and web browser, you should be able to updat the RBS first, then RBR lastly.
- Mkerr33Aug 20, 2019Tutor2.3.1.44 is the firmware
