MGScott
Apr 26, 2020Tutor
Firmware update on RBS50 fails
Note: Model above is incorrect, would not let me select RBK50 I have an RBR50/RBS50 setup that I am trying up put into service. It is running V1.1.0.16. I am trying to do the first stage man...
- May 26, 2020
Try v2.0.0.74 first on the RBS...
MGScott wrote:Finally getting back to this.
Okay, so I log into the satellite (IP easy to guess, since currently only 3 nodes).
Select Firmware update and browse to "RBS50-V2.2.1.212.img".
I get the following message, "Please select correct configuration file".
Retired_Member
Apr 26, 2020Why do you want to update?
problems with your system?
- MGScottApr 26, 2020Tutor
Factory-installed firmware V1.1.0.16 lacking features.
