MGScott
Apr 26, 2020Tutor
Firmware update on RBS50 fails
Note: Model above is incorrect, would not let me select RBK50 I have an RBR50/RBS50 setup that I am trying up put into service. It is running V1.1.0.16. I am trying to do the first stage man...
- May 26, 2020
Try v2.0.0.74 first on the RBS...
MGScott wrote:Finally getting back to this.
Okay, so I log into the satellite (IP easy to guess, since currently only 3 nodes).
Select Firmware update and browse to "RBS50-V2.2.1.212.img".
I get the following message, "Please select correct configuration file".
Retired_Member
Apr 26, 2020Why do you want to update?
problems with your system?
MGScott
Apr 26, 2020Tutor
Factory-installed firmware V1.1.0.16 lacking features.
- Retired_MemberApr 26, 2020
MGScott wrote:Factory-installed firmware V1.1.0.16 lacking features.
why not let NG figure that out and push the next update you need?
- MGScottApr 26, 2020Tutor
Because for versions prior to 2.2.1.210 must perform a manual update to 2.2.1.212 first.
- CrimpOnApr 26, 2020Guru - Experienced User
We have two topics going.
- How to manually update?. My guess is that the web browser should be connected to the satellite, rather than the router.
- Why not let Netgear take care of this? I fear that firmware back in the "1" series may be "too old" and Netgear's update logic too confused to properly handle this. For example, Netgear's logic may think that any Orbi from "back in the day" was surely automatically updated (over and over) and no longer recognizes something that old.
This is easy to test: Leave it alone for a week (7 days). If it hasn't updated automatically by then, it is not likely to.
