MGScott
Apr 26, 2020Tutor
Firmware update on RBS50 fails
Note: Model above is incorrect, would not let me select RBK50 I have an RBR50/RBS50 setup that I am trying up put into service. It is running V1.1.0.16. I am trying to do the first stage man...
- May 26, 2020
Try v2.0.0.74 first on the RBS...
MGScott wrote:Finally getting back to this.
Okay, so I log into the satellite (IP easy to guess, since currently only 3 nodes).
Select Firmware update and browse to "RBS50-V2.2.1.212.img".
I get the following message, "Please select correct configuration file".
CrimpOn
Apr 26, 2020Guru - Experienced User
You are correct that the Release Notes state that versions up to 2.1.2.210 require updating to 2.1.2.210 first. That was because back in 2016 when the Orbi was designed, nobody though the firmware file would grow as large as it did, and there was a "maximum file size" hard coded into the firmware update process. 2.1.2.212 was released specifially for the purpose of increasing that file size limit.
Are you trying to update by connecting to the router "Firmware Update" web page or connecting to the satellite "Firmware Update"?
MGScott
Apr 26, 2020Tutor
I am logged into the web interface on the router.
Browse to the unzipped .img file for the satelite and click upload.
