MGScott
Apr 26, 2020Tutor
Firmware update on RBS50 fails
Note: Model above is incorrect, would not let me select RBK50 I have an RBR50/RBS50 setup that I am trying up put into service. It is running V1.1.0.16. I am trying to do the first stage man...
- May 26, 2020
Try v2.0.0.74 first on the RBS...
MGScott wrote:Finally getting back to this.
Okay, so I log into the satellite (IP easy to guess, since currently only 3 nodes).
Select Firmware update and browse to "RBS50-V2.2.1.212.img".
I get the following message, "Please select correct configuration file".
MGScott
May 25, 2020Tutor
May 26, 2020Guru - Experienced User
- MGScottJun 03, 2020Tutor
Thanks FURRYe38, that did the trick.
I updated both manually:
V1.1.0.16 -> V2.0.0.74 -> V2.2.1.212 -> V2.3.0.32
Then let it do the final version V2.5.1.16 automatically.
I also re-downloaded firmware in case original was corrupted, but that was probably overkill.
Thanks for all the help.
- FURRYe38Jun 03, 2020Guru - Experienced User
Great to hear, ya, v74 is key if the orbi is on v1x version.
Glad you got it working. Enjoy. :smileywink:
