Soccerphysio
Jun 15, 2019Aspirant
Firmware update question
I’m a new (3 month) user of my Orbi system (and I’m not tech savvy, so please forgive my basic questions here!), and I’ve have had no problems at all, works great! I’ve received a few emails stating...
Jun 15, 2019Guru - Experienced User
Yes it's safe to reboot. it maybe not getting a good update check and wants to reboot to be sure. You maybe on older FW which may have already autoupdated.
Soccerphysio
Thanks for the reply! I cannot find the info on my modem, its the one provided by Charter/Spectrum Cable, there’s no product info located on it.
- FURRYe38Jun 15, 2019Guru - Experienced User
Modem info would be helpful. Is there a sticker behind or under the modem giving model# info?
You can use a wired PC and web browser and navigate to your RBRs web page and log in and look at the Internet status. Do you see a ##.##.###.### address there or a 192.168 or 10.something address listed here.
Just checking to see if the modem may already have a built in router.
- SoccerphysioJun 15, 2019Aspirant
The only info I can see is “MO 2151009228-01L1”, in addition to a “CM MAC” and “MTA MAC” number.
I really appreciate your interest in helping!
- FURRYe38Jun 18, 2019Guru - Experienced User
Any update on this?
Can you post a picture of the ISP modem?
