Badger894
Mar 25, 2020Follower
Firmware Update RBR40 says updated but check version and still the same
Hi - I’m on FW 2.3.5.30 and trying to update to .32. I go thru process with app and it says it updated, but then when I check version in app it’s still the same and continues to tell me there’s a new ...
Mar 25, 2020Guru - Experienced User
You can manually download FW files from NG download site if you wish to update.
Badger894 wrote:
Hi - I’m on FW 2.3.5.30 and trying to update to .32. I go thru process with app and it says it updated, but then when I check version in app it’s still the same and continues to tell me there’s a new version. What can I do to make sure it’s Truly updated?
