goonerbob49ner's avatar
Feb 25, 2023
FIRMWARE UPDATE RBR50 /RBS50 to V2.7.5.4
Hi
I'm trying to update the Orbi router and satellites to the firmware v2.7.5.4 from v2.7.4.24.
The online update is saying the firmware is up to date, however Netgears download page has the V2.7.5.4 available as per the links
https://kb.netgear.com/000065539/RBR50-RBS50-Firmware-Version-2-7-5-4?language=en_US
Have tried the manual update route by downloading the zip file (extracting) and uploading to do the satellites first as per the instructions in the user manual. However, it keeps coming up the firmware file is wrong!!!(see screenshots attached).
Any help would be welcome
Bobby
1 Reply
  • plemans's avatar
    On your pdf, you're trying to install the satellite (rbs) firmware to the Router the RBR.
    That section is for the router. When you click update on the lower one for the satellites, it should open a separate page for the satellites. Or you can just navigate to them using their ip addresses and do it through their own gui.
