randomousity
Mar 24, 2021Luminary
Firmware update service unavailable
If I go to the firmware update page, it shows "service unavailable" as the status for both the RBR50 and RBS50. Is anyone else experiencing this? Is it a server/hosting issue on Netgear's end? Intern...
- Apr 21, 2021
This is a NG Cloud service issue. Not FW or anything users can adjust for. Contact NG support for help and infromation.
Usually comes back on it's own or after NG fixes it on there side.
Good Luck.
ghenry1111
Mar 24, 2021Aspirant
Yep... seeing the same situation here on my RBR50.
Mar 24, 2021Guru - Experienced User
Nothing to do with FW. This is a NG service side. Happening on Orbi AX as well.
Someone can contact NG support to let them know if they want to. Someone from the Orbi AX side already did.
