MichelvanEunen
Jun 24, 2023Aspirant
Firmware update shows many sattellites
Helllo, When i go to my firmware update screen it shows many many times the same sattellite RBS50. IT is in that list hundreds of times again and again. Is there someone who can explain this to m...
Jun 25, 2023Guru - Experienced User
If the recommended reboot doesn't work, you can try a simple factory reset and reinstall
