GamerHonu
Nov 30, 2016Star
Firmware update URL?
Does anyone know the URL that Orbi is using to automatically check for firmware updates? Thanks!
- Nov 30, 2016
GamerHonu wrote:Does anyone know the URL that Orbi is using to automatically check for firmware updates? Thanks!
To my enormous surprise, it doesn't use HTTP. It does a passive anonymous FTP connection to updates1.netgear.com (216.151.177.114) and hits directory "rbr50/us" (which fails). It then tries again (by disconnecting and reconnecting) and hits directory "rbr50/ww", looking at fileinfo.txt to see if an update is available. (I'm already updated, so I'm not sure what it does next - the directories and files are hidden.)
The content of fileinfo.txt appears to be binary, despite the extension, and contains a _lot_ more data than one would expect for a simple version marker (it's currenly 6948 bytes in size and filled with data).
There is a "rbs50/ww" directory as well, which I assume the satellite uses.
You do get a fun scary banner on connect:
230- 230- --------------------------------------------------------------------------- 230- WARNING: This is a restricted access system. If you do not have explicit 230- permission to access this system, please disconnect immediately! 230 ----------------------------------------------------------------------------
I don't know, if as an owner of the device, if I have explicit permission to access, but I'm willing to live dangerously. *laughs*
Note that it will ONLY use unencrypted FTP - there is no HTTP(S) fallback. If you block port 21 outbound, a firmware update check results in "Service unreachable" on the router...take note, outbound firewall lovers!
(I'd really, REALLY like to see this done in a much more secure way - this method is not only ancient and firewall-unfriendly, it's completely insecure and wide-open to MITM injection attacks. HTTPS/TLS with certificate validation would be an infinitely better option.)
Rodney
rhester72
Nov 30, 2016Virtuoso
Rodney
