NTCE
Feb 15, 2021Guide
Firmware update V2.6.2.104 - Internet Freeze, No Internet, Buffering, OFFLINE Status on App
I am having issues since the New Router firmware update. Hardware Version RBR20 Firmware Version V2.6.2.104 GUI Language Version V1.0.0.375 Operation Mode ...
vajim
Feb 17, 2021Master
simpler solution....
Perhaps you should revert your firmware
Thornemat
Feb 17, 2021Initiate
Reverting the Firmware's a tempting suggestion. Any suggestions how would be gratefully receieved.
- vajimFeb 17, 2021Master
Thornemat wrote:Reverting the Firmware's a tempting suggestion. Any suggestions how would be gratefully receieved.
there are several posts here that talk about how to do it. here's one:
https://community.netgear.com/t5/Orbi/Orbi-RBR50-RBS50-Cannot-downgrade-firmware/m-p/1836166
you are basically going to the download section here and enter your model number and see if the rollback firmware is available.
- KooymanFeb 20, 2021Initiate
gisteren hebben we de firmware vd router en de 2 satellieten allemaal teruggezet naar dezelfde versie als daarvoor.
Resultaat: alles werkt weer zoals vroeger, snel en stabiel.
Hopelijk heeft iemand hier iets aan.
- thiyagarajMar 31, 2021Aspirant
Yes, reverting to old firmware seems to be resolved the issue. go to netgear download page, and manually update the firmware.
- junktrunkMar 31, 2021StarReverting to old firmware may resolve your issue but still exposes you to the same security issues NG decided were severe enough to warrant updating these products in the first place. It's not a good solution.
Instead, it seems like NG is acknowledging to some people that the issue is in Traffic Meter. So before anyone downgrades firmware, please start by just disabling Traffic Meter with the current firmware. That seems to be doing the trick for me.- vajimMar 31, 2021Master
Instead, it seems like NG is acknowledging to some people that the issue is in Traffic Meter. So before anyone downgrades firmware, please start by just disabling Traffic Meter with the current firmware. That seems to be doing the trick for me.or in my case...never upgraded in the first place....and the security is fine
